Save fuel with a POSIVLOW.......really work???
This unit allows you to save up to 20% of fuel costs, by aligning the particles of the fuel, thus improving oxygen flow making combustion easier and more efficent.
If it really did work someone, would have made an absolute fortune out of it. Snake oil...
Taken from here:
1. The magnets are tiny, and pretty weak. There's no demonstrable effect of these things on hydrocarbon liquids such as gasoline (petrol) or diesel. A magnet cannot provide oxygen and neither can it change the amount of heat released from burning the fuel.
2. Liquids cannot "retain" any magnetic effect when they leave the magnet, even if affected when within it. Hence you cannot "charge up" a liquid in the way that a dust particle can be charged.
3. There is no truly independent lab analysis which could give evidence that combustion can be improved nor that you'll get better power output or lower emissions. The "labs" that give reports and testimonials to the various magnetic product companies are either on their payroll, or received generous "donations". No conflict of interest there then.
4. A modern car engine will typically fail to completely burn something like
