ENGINE WARNING LIGHT ON JUST AFTER A SERVICE .. CODE P1163
Just had car serviced got home .. next morning got in started engine and engine managemnet light came on ... my friend found fault code p1163 ... anyone have any experience on this ... Fuel Temp sensor i think ???? coolant temp sensor ??? help would be greatly appreciated
17571/P1163/004451 - Fuel Temp Sensor (G81): Open or Short to Plus
Possible Symptoms
  • Fuel consumption higher then normal
  • Starting the engine is not as easy as normal
  • Emission Levels not met
Possible Causes
  • Wiring/Connectors from/to Fuel Temp Sensor (G81) faulty
  • Fuel Temp Sensor (G81) faulty
Possible Solutions
  • Check/Repair Wiring/Connectors from/to Fuel Temp Sensor (G81)
  • Check/Repair Fuel Temp Sensor (G81)
It doesn't mention anything about the EML coming on though!
A faulty temperature sender will cause the EML to come on and log a fault code. The engine ECU will derive a substitute value for an implausible reading so little or no performance loss may be noticed. When the faulty sender is replaced the EML will extinguish but the fault code will remain logged.
Early coolant temperature senders (black body) were potted in hard epoxy and thermal cycling fractured the brittle NTC elements with them. The later green ones are a bit more relaible. Avoid the Chinese ones selling for about £5 - GSF have good replacements.
rotodiesel.
Ah Mr Rotodiesel, you have explained the mystery of the old CTS, I always wondered what the problem with them was.
I don't know where the fuel temp sensor is but it does seem like someone spent a while poking around under the bonnet and now you have a warning so my first thought is has something been disconnected/damaged/pulled/bent. I would be back off the garage who serviced it.
The EML light has stayed on .. and cannot be erased for some reason ... yes i took it back to same garage .. hes getting a temp sensor tommorow ill repost the results ..thanks for the help
Yes it was faulty Temp sensor ... 2 second change and it worked fine .. EML light still stayed on but we cleared that with computer ... it would not clear the last time so all looking good ... thanks .. the joys of being a taximan !! lol
