Fitting de-cat down pipe
Now I'm pretty competent as a mechanic and really don't mind getting my hands dirty on the car! I've had a quick look and it looks fiddly but fairly simple.
Is it really that easy?
Thinking of getting a Piper down pipe and mating it to the standard cat back for now, what I think will be the issue is seperating the cat back and down pipe as it looks corroded under there!
Three nuts at the turbo (M8) and a clamp joining the down pipe to system. If the down pipe and system joint is seized then heating it should get it moving.
As easy as I thought then :D good job we have a few blow torches then :) thanks for the help will order one soon!
Do I need new gaskets for anywhere?
I fitted a new gasket 3A0253115 and 3 nuts N90200201 from TPS and a 60mm stainless clamp from Pirtek, under £10 for the lot.
I done the 1 from the top and the lower 2 from underneath as found it easier to get onto, some people to the 2 from the top but i just couldnt get good leverege. A normal gasket from dealer/motorfactors is all you need.
Thanks! Found the gasket on ebay! Just wish this month wasn't a 5 weeker lol
Know the feeling mate. payday is still ages away!
Hope you like the piper de-cat.
