Vibration at between 1500 - 2000 rpm
Hi all
I have a 2007 mk1 skoda superb 1.9 tdi 115bhp, the problem I have is when I accelerate I get a vibration at around 1500 - 2000 rpm and then it seems to go away any ideas what the problem could be its very annoying
mine had the same,and it was my xenon box vibrating against metal...took long to find out :-)
Mine is a bit more than that the whole front seems to vibrate then goes away
Hi Javy,
I had a very similar problem on my Superb in the same rev range you described, more so in the lower gears, but still loud enough to hear in higher gears. I traced mine to the air intake trunking on the driver's side of the engine bay at the point closest to the windscreen where it joins the airbox. Try getting someone to hold the rev's steady in the range that causes the vibration and then carefully press down on this trunking to see if it's the cause.
Hope this helps!
(Signed up specifically to post this!)
Edited by Flurry
