octavia VRS rear caliper rebuild?
has anyone on here rebuilt their rear calipers?  just discovered my right rear is seized solid, cant even turn the piston, ill try and source a replacement as i think ill break this one before it frees..
no worries you won't break it. had mine (rear right) solid about 3 weeks ago. broke the pin on the rewind tool but managed to get it back going until the replacement arrives. as an immediate effect the fuel consumption dropped drastically  :D
and regarding rebuild: i've seen brand new TRW calipers go for under 100 euro. for that money i would rather buy a new one...
I have rebuilt my rear caliper few times, first time successfully, second time not so.
Fist time i could not use wind back tool as seized bad. So off came caliper unwound piston. It was seized because seals had failed and piston was cruddy and pitted a bit. I cleaned it up and also fitted new rubber seals. Seem to work good for  a while. However the VRS rear caliper is a poor one as the combination of hand brake / foot peddle to the piston coupled with a sloppy hand brake cable return mechanism causes common caliper binding / seizure.
Second rebuild did not work. Fact is a replacement rear caliper fully primed with fluid is less than £70. why bother messing
true which is what i got and fitted few weeks back and working great for now..
May I ask where from, Mark? Cheapest (green ones) I can find are £93 with £12 cashback. I need a pair next time I do my pads, as the nearside bleed nipple has completely seized, and I might as well buy before the price goes up. But then again, I suppose it could go down...
Of course you can buddy
this is the one i bought
http://www.ebay.co.uk/itm/Skoda-Octavia-1U2-1996-2009-RS-RIGHT-OS-REAR-brake-caliper-GREEN-new-/150893393155?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3ASkoda%7CModel%3AOctavia%7CCars+Type%3ARS+1.8+T&hash=item2321f27503
This is the n/s rear one also
http://www.ebay.co.uk/itm/Skoda-Octavia-1U2-1996-2009-RS-LEFT-NS-REAR-brake-caliper-GREEN-new-/160877110765?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3ASkoda%7CModel%3AOctavia%7CCars+Type%3ARS+1.8+T&hash=item257505e5ed
They are original OEM and painted green and fluid primed.
I doubt these prices will go down, as seems to be getting more common to see rear calipers on these older VRS failing.
Cheers Mark. :)
thanks for the info, yeah i think ill just bite the bullet and order a new one, or both if i can sell one of my other cars soon.. cars of the road though.. :(
  • 4 weeks later...
ordered 2 new ones today,   should have them for the weekend, get this wagon back out of the garage, been too many weeks!!!!
I have just fitted two new ones to y vRS. Shame I didn't know BOTH we're seized, could have saved myself £28 and got a pair for £120.
Going to have a go at rebuilding mine and if successful ill either sell them on or keep as back ups.
