Fault code 9479189
I can't find much on this fault code except from people who have retrofitted FL AC panels into pre-FL Octavias. There's also little outside of this forum that I can find.
               Address 08: Auto HVAC       Labels: 5K0-907-044.clb
Control Module Part Number: 3T0 907 044 AS    HW: 3T0 907 044 AS
 Component and/or Version: Climatronic   H15 0401
          Software Coding: 0000000002
           Work Shop Code: WSC 73430 790 00999
             ASAM Dataset: EV_Climatronic A01006 (SK35)
                      ROD: EV_ClimaAutoBasis_SK12.rod
                     VCID: 030F76F88A23482640-8056
1 Fault Found:
9479189 - Signal Line for Air Quality Sensor
         B10A4 15 [008] - Open or Short to Plus
         Intermittent - Confirmed - Tested Since Memory Clear
            Freeze Frame:
                   Fault Status: 00000001
                   Fault Priority: 3
                   Fault Frequency: 1
                   Reset counter: 62
                   Mileage: 109132 km
                   Date: 2015.11.02
                   Time: 21:49:00
Basically it posts to a fault in the wiring for the air quality sensor. But where is it on a Yeti and what does it do?
I've not changed anything electrical since I retrofitted a Columbus and MDI; so can;t work out why it has cropped up since then.
Any thoughts?
I thought it was on the air intake into the cabin before the pollen filter. Probably deep inside the dash.
Sent from my D5803 using Tapatalk
I changed my pollen filter last month. Is it possible that I've damaged a wire or dislodged the sensor?
Never had any issues with my Octavia.
Thanks for the links. Still not 100% sure where it is, but will have a look shortly.
The first link doesn't allow me to look at the forward links to removing the bodywork. Is there a way around this?
