No heat in car
Car blowing cold air only into superb, temp gauge went above the 90 in dash,,, like a fridge inside ..help plz
If you've got Climate, there's a "demand temperature" display in its panel. It also has its own control blocks in VCDS.
Thanks ken, but that's all new to me, lol
Sounds like a trip to the garage then...
If your temp on the dash went higher than 90 it would imply your water has got too hot unless the sensor is faulty.
I would be checking to see if my water was circulating (pump failure?) and the level was good.
Edited by jimbof
Thanks jim, when I start my car in the morning I drive till my temp hits 90 but still blows cold air, after around twenty mins the heat suddenly comes on, on two occasions my temp went just above 90 and had to top up water ,,,but once the hot air is on it stays on all day,
