Removing front wing
Does anyone know how to take off front left wing?
Need to repair but I would like to do it by me.
Tnx
Remove headlight and underside plastic splashguard, slacken bumper and pull forward away from the wing, undo four bolts on the inner door post, two bolts into the outer sill, open bonnet and remove all bolts from the top of the wing, lastly undo three bolts to the lower front panel, some of the bolts you will find are covered in underseal, that will need scraping off to get at the head of the bolts, then lever the wing off, replace in reverse, check your bonnet and door gap before tightening up new wing, job done, should take you about an hour
this is for passat - but should be very similar i guess
Tnx very much!!
