MFSW Retrofit
Can anybody advise on what parts are required for me to retrofit a MFSW to my 62 plate Octavia vRS Blackline with Maxidot?
I'm aware i'll need the new wheel with buttons, a new stalk (minus trip buttons), possibly a module and/or control unit depending on what I currently have fitted and some coding.
I wouldn't know what spec the Blackline has when it comes to the steering wheel with regards coding, the module and control unit so any help here would be much appreciated.
Thanks in advance.
Apart from the steering wheel and airbag loom you will probably need a new control module. There is a guide on ross-techs site here which details which control units cater MFSW, cruise etc. Have a look on my build thread as I have done the swap on my car. if you plan to use the steering wheel from a Mk3 Octavia then you will also need the buttons from a Yeti or Superb Mk2 FL as the Octavia 3 ones will not work.
