I can see Gandalf's Pressure now!!
woOot 😁
After months n months of planning, I finally retrofitted the Direct TPMS (Tire Pressure Monitoring System).
It all went well and everything is working as expected.
Turns out the module (5Q0 907 273 B ) was already parameterized (the VCP bit), so once I did the VCDS coding bits, it was all running.
I will however need to update (via VCP) the TPMS module's parameter file so it has the right tire profiles, but it's all good
