door arm rest rattle
Hi,
the passenger door handle/arm rest (the bit with the leccy window control on it) seems to rattle due to the bass from the speakers.
Im talking about minimal bass here, like someone with a deep voice on the radio, the armrest is vibrating like mad.
Anyone know a way of dampening it ?(without having to lower the volume or bass to zero). I was wondering whether the plastic is clipped on, in which case i could probably jam a piece of card in somewhere to stiffen it up.
cheers
The armrest top itself slides forwards and backwards if the front switch panel isn't properly located.
The switch panel has a hook type arrangement behind it and a clip type arrangement on the front. The clips are horrible |_| shaped ones with a hole in the middle. Either the hooks or the clips can wear/weaken with removal and not sit right again.
Blue tack may be your friend.
J.
