Got Bluetooth - phonebook/open circuit!
Recently installed Bluetooth module 7P6...730E on my 59 plate octy, started working (apart from phonebook) even before any coding. I understand phonebook issue is because the module is too new for my bolero unit, I'll have to live with that because can't justify new bolero.
Had pre-arranged with briskoda member martziniuk (very big thank you) to do some coding, scan showed a couple of errors relating to radio which were cleared but one that at time we could not clear;
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 E    HW: 7P6 035 730 E
   Component: TELEFON       H09 2730
   Revision: 1B001001    Serial number: 00007660442144
   Coding: 0A01000000010101
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_UHVNA A01015
   ROD: EV_UHVNA_SK35.rod
   VCID: 346C019F9F8C7BB8F54
1 Fault Found:
9458195 - Control Module for Cellular Telephone
          B1052 13 [009] - Open Circuit
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 22
                    Mileage: 46655 km
                    Date: 2037.14.21
                    Time: 00:00:01
Have since found a post by Eddie-NL that suggest a code change, that proved successful.
Coding: 0A01000000010101 change to Coding: 0A01000000010110
My question is how important is that 'open circuit' fault be cleared? Can it wait till I next get some coding done, or should I sort it out quickly? (martziniuk very kindly said any problems call back, but I don,t want to take up any more of his time unless necessary).
stop worrying about it, the fault is there because the phone module is looking for something that is not there
Thanks Eddie, the worrying has ceased!
