Everything posted by neilybs6369
2012 Skoda fabia greenline 1.2 TDi
Yer sorry I'll try in the sun light if it stops raining
Hello all. Just wanted a second opinion on this cam belt please. This belt has done 45650 and was changed back in 2017. Is it still good for a while or would anyone recommend a new one? Thanks..
Rollin down the road
Thanks all. I just got back from a professional garage. They did a laser wheel alignment and had a good look while up on the ramp. The work I had done yesterday was new back bushes and two front wishbones with ball joints. The only damage he showed me was one of the nearside wishbone bolt ends had sheared off where it had landed on the road. Also the inside of the nearside alloy wheel had some deep scratches were the disk had hit after the wheel came off the hub. The car is running true again and all seems well at this point. The only annoyance is I seem to be noticing a lot more road noise after the new bushes. Maybe I getting paranoid or they will settle in soon? Thanks for your support guys.. 🙂
I'm telling you or anyone on here, I am asking advice!! That's what this forum is all about.
Hi all. Long story short. After getting some work down at a local garage today as I drove away at about 10 MPH my front nearside wheel flew off down the road. The mechanic had got distracted and forgot to tighten the nuts up. 🤣. They put the wheel back on with many apologies and I went on my way. Want damage if any might of happened and what should I be looking for? Its is pulling over to the left a lot more than it was.. 👍
2012 Skoda fabia greenline ll 1.2 TDi estate.
Thanks. That's really helpful.. 😉
Hi all. After hoovering under the front passenger seat and moving this dangling switch out the way a bit my rear wiper arm stopped moving and is stuck. Is this likely to have caused it to stop or is it just bad timing? The jet wash is working as normal. Checked the fuse which is fine. The wiper has been working fine until yesterday? Any help would be greatly appreciated thanks.
Hi all. I had the word clutch come up on the dash a couple of times over the past 6 months and was wondering what it means? Also in the past year the clutch has not come back up a couple of times while driving and I had to pull it up with my foot. Apart from that it has been functioning as normal. Thanks in advance..
2012 greenline 1.2 tdi estate.
Thanks guys. Love this little tank…
Thanks 👍
If they were leaking would they just give up at some point? Can a leak be fixed or would it be a replacement job? Cheers.
Hello guys. Just wondering if this light oil misting build up could be cause for concern? I thinking are the injectors on their way out? What is the cost if so? Much appreciated in advance…
2012 Skoda Fabia 1.2 Tdi greenline.
Thanks 🙏
Hello guys. So I've had the wheel alignment done and the tyre pressures all good and correct all round yet its still gently drifting off to the left. Even my trusted local garage couldn't see anything obvious... Any ideas please?
Whistling engine noise
I’ll try and do a video later when the roads are quiet but not heard it properly since that long journey on Tuesday. The only time I’ve noticed it seems slower is sometimes in first gear it take 2-3 seconds before it get a shove on like it’s lost power for a couple of seconds. Apart from that once it wakes up it goes well for a little 1.2 tdi.. It was 23.5 here today and I thought I could hear it again but the traffic and wind was very loud so not 100% sure. Whatever it is it’s not constant but random…🤔
Where do I look for that please?
Hello guys. After driving 170 miles home yesterday I parked up for half an hour before popping to the shop. On my journey to the shop I became aware of a whistling engine noise even when idle. Next day nothing but only drove a few miles. The car has done 74k and had the cam belt & water pump changed at 52k 2017. Any ideas guys? Thanks. 2012 Skoda Fabia estate 1.2 TDi greenline
Thinking of buying?
Thanks. I had a VW Passat 3 years ago and wondered why the DPF light never came on once. Turns out the previous owner had ignored the book an appointment for the fix emails. Cheers 😉👍
Thinking of buying?
Hello guys. I am looking at a 2013 1.2 TDi roomster greenline 2 with 60K on the clock. The car is in great condition with a brilliant history but my only concern is the dreaded DPF.. The guy has not had the light come on yet. It has been in and had the EA189 emissions fix done, so would this fix contribute to future regen problems or be a help? Has anyone had regen issues with this same car? If so at what mileage are the problems likely to occur? Many thanks in advance. 👍
DPF
I had a 2008 Fabia 1.4 TDI without one issue in the time I had it. Not nuts mate just asking for a bit of advice.
DPF
Thank you so much that is very kind of you 😉
DPF
I've been looking at 2009 Skoda Fabia Est 1.4 TDi. My last skoda Fabia Est was a 2008 1.4 TDi which did not have a DPF fitted.
DPF
Hello guys. Can anyone tell me what year the DPF's were introduced on the Skoda Fabia TDi.. Or what was the last year before they fitted them? Ta in advance...
1.2 TDI Greenline
Never had any trouble with my 1.6 TDi Passat blue motion or my 1.4 pd engine Fabia.
