Hi,
may I kindly ask your support and guidance with the situation I am facing?
Octavia III 1,2 TSI, 2005, ca. 65000 km, owned from new by me and the car has been absolutely trouble free up to now.
I changed from winter to summer wheels
When starting the car afterwards and driving I got the following messages:
tire pressure warning (that was correct, as I had not stored new settings after the wheel change). So I stopped and stored the settings
ABS/ESC failure
tire pressure again
AFS failure (cornering light)
Start/stop failure
Light on the button for the parking sensors is blinking
Stopped the engine, waited and tried again with unchanged results.
While I could imagine that I might somehow have done something to a ABS sensor during wheel change (even I did not touch them, not even the cables and have done wheel changes countless times), most failure messages did not seem to have any connection to the wheel change. I suspected a battery problem and measured voltage at the terminals: 10,1 V which is obviously very low.
I had the battery over night connected to a charger. This morning I disconnected, waited for 5 min and measured 10,36 V, which seems to indicated a ca. 50% charged battery.
The battery is still the original so no reason to complain that it seem to have reached end of its life.
Are all the failures I gut indicated consistent with a faulty battery or should I suspect anything else?
Thank you in advance
