Everything posted by Jokkmokk
Thule WingBar Evo with 775 feets?
Yeah, I like the aero design from lots of perspectives. Also the look when the bars sticks out a bit (though not to much), to me it gives a more rugged and adventures look. The flush roof bar things doesn’t play as good together with the Yeti in my opinion. But then again, if the bars will stick out a good 10cm from the rails, that isn’t either...
Are you using or have used these on a Yeti? Curious on how much wider they are from the rails.
Hm, are you sure these are the same feet? This is what the setup looks like with WingBar and the 775 feet.
Ah, okey now I understand. And yes, of course I will make sure to put the rubber strips in. Besides from reducing annoying whistle sounds they have I purpose of adding friction and protection when loading things directly on the bars. The only thing I really need now is some photos of a Yeti with these mounted... 😅
- Skoda Yeti grille mod
Hi, I’m working on a modification on a used Skoda Yeti grille. I have removed some of the bars in order to make a more aggressive look. I’ve also glued some small plastic bits to the underside in order to have some support for what I will fill the gaps with. I’m thinking of filling the gaps with some sort of putty and the sand it all level. The whole thing will be painted in matte black. Now, will this work? What could I use in order to fill the gaps with? I’m guessing the hard part will be to find a solution that will not result in cracks of the “joints” between the grille and the putty (or whatever I may en up using). Cheers
@gumdrop @Dale_Stevens Haha... confused I am... 🐸 Do you mean on the WingBars them self or the bars attached to the car? Haven't seen anything resembling a sealing strip while looking around and boy have I looked around... The WingBar Evo looks like this underneath, do you mean the two “gaps” that runs down the bar?
@gumdrop Hm, not quite sure what you mean by that? What slots? 🙈
Hi, I'm looking for a couple of roof bars for my Yeti. Right now I'm leaning towards the Thule WingBar Evo 127 (in black) with the Thule Rapid System 775 as feets. Does anyone have this setup on their Yeti? It would be awsome if someone could perhaps post a photo on how these looks on the Yeti. I like (I think) the look of the bars and the feet but I'm not sure how far out the bars will go on the sides and what that will look like? Cheers
