haris
Everything posted by haris
  1. Hi, thanks for the answer. Is there any other upgrade solution? Maybe 312 or 330 . From which cars/ models to check ebay? I would prefer a non heavy solution of course to avoid problems
  2. Well..is it a straight swap? Are they heavy brakes compared to.my stock 288mm ? Will this change create problems?
  3. Hi I.have a 2014 a7 1.4 140hp model . I found a used set front and back from audi s3 8p . 345 front and 310 back Now I.have 288 front and i don't know back Can i install them? Will I have any issues? Do I need extra parts? Also what is the minimum rim size I can use? 17 or 18?
  4. I bought the car 2 years ago and this battery is fitted. Varta silver 60 agm I thought it was the first one from the factory. My mechanic also said that this type and brand must be the car's stock battery I was very pleasant 2 years now from the battery and I'm thinking king to buy the exactly same again
  5. So, is it a straight swap or needs coding? Sorry but my English is not so good and I didn't understand yet.
  6. Start stop working nicely, although I don't use it often. But stopped working, then worked 2-3 times and then didn't work again The battery I think is the first one and is AGM . I just want to replace with the same one My radio is aftermarket by the way
  7. Hi, I have a 2014 model 1.4 140hp It has a varta silver dynamic 60ah battery and start stop stopped working. I think I need a new battery. My question is : if I buy the same exactly battery , can I replace it myself or it needs coding or any other tricks? I asked everywhere and the want 150-160 euros I found the same battery 115 euros.
  8. hi, I know that a lot of people use this type of reverse camera from aliexpress.. https://www.aliexpress.com/item/32952930178.html?spm=a2g0o.productlist.0.0.556c7d91PFCJzU&algo_pvid=b026bed8-3c8a-4e2a-828b-3176133bf2c3&algo_expid=b026bed8-3c8a-4e2a-828b-3176133bf2c3-0&btsid=0be3769015917848285252996e3704&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_ I saw a new model which supposed to have double resolution and double tv lines.. does anyone already tried it ? https://www.aliexpress.com/item/4000760949603.html?spm=a2g0o.productlist.0.0.7a7e59f9JqVSMA&algo_pvid=8f1b4e09-888d-4f3e-be12-7d29fae3d52d&algo_expid=8f1b4e09-888d-4f3e-be12-7d29fae3d52d-14&btsid=0ab6f81e15917844683903654e65d8&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
