Everything posted by Lico
Trim and C pillar remove guide
Pictures are now in the Yeti gallery!
Leaking Panoramic Roof - The Cause and the Cure
Also seen here the sealant problem
The procedure was as followed......... I liften up the rubber Outer seal off the panoroof up a little bit and put in the nozzle off the sealant and little by little put in the sealant in the gap underneath working from half off the roof to and trough the corner to the other front corner and up to the other half off the roof. I didn’t do anything on the inside off the roof or roof cassette. it certainly did the trick on my car. my roof was leaking at spot in photo inside car. Have no experience with wrapping the panoroof........hope it stays that way 😉
Rear Interior Lights and Number Plate lights ...
You can see the rear interior lights here....... regards Lico
My Panoroof was also leaking. Took out the headliner and checked all hoses and what not. Turns out that there was hardly any sealant underneath the front outer sunroof seal. Fixed it with 3M 08509 sealant. The last couple of days we had a lot of rain and there was no leak anymore while driving and parked. If that doesn't work and you still want to keep the car for years to come you can wrap the whole roof. You cant use the panoroof anymore,"panoroof delete" but you can still enjoy your Yeti. Regards Lico
Hello Simone, Take a look in the Yeti gallery for photo's of my Yeti with the headliner removed. You can see details of the C pillars and more. It took me about 2 hours (alone) to remove all the trimmings and headliner. I work in a very tight garage and could not open my doors so the only way in and out off the car was through the trunk :-{ Removing the headliner and trimmings is not that difficult, it just takes some time to remove the trimmings the fist time if you don't know how they are attached to the car. The headliner removal out off the car is a two person job to make sure not to twist it. Currently my headliner is still out off the car and is going back into the car coming Saturday. I can make some detailed pictures tomorrow of the sunshade and the center seatbelt if you want. I will post it in the Yeti gallery. Regards, Lico
