Agalalh
Everything posted by Agalalh
  1. Very good point but how we can measure water in rad
  2. Without thermostat which switch i have installe
  3. We already have a lot of products from turkey but it's dependent of the market needs and here in egypt felicia very old fashion 🤣🤣
  4. Thanks for your advice really i need to change Rad
  5. Thanks for your reply But as I said before I am not found thermostat lower than 87c in egypt so im used switche 80-90 which strat fan at 94c i think it's too much without A/C So do you have another solution Tomorrow ill try switch 88c
  6. Hi all thanks for reply I found switch 86_76 and I'll try it But still waiting more advices
  7. Thanks for your reply But here in egypt it's not easy to find thermostat 80c do u have another solution Thanks again
  8. Hi All have a nice day i need ur advice in this issue i have felicia 97 GLX & 1300 cc with Carp. i am installed thermostat 87 C & thermo-switch 80-90 C is suitable for Summer in Egypt in Egypt now it's 40 C or (95 F) Fan start at 94 c and stop about 88c which it's so hot starting need your suggestion which suitable Thermostat_ switch start before 94 c Keeping the fan turned on and off so that it does not run continuously thanks for your time
  9. Hi all Felicia 97 glx 1300 carb. Speedometer Bearing full of oil I had changed but still get oil up Thanks
  10. System only From carbo to inj. In the same engine
  11. How i know the different between DB carbo and DB injection
  12. Thank you Ricardom Do u have another solution if i can't found DBi How could I know if this DB for injection?? Do you have a code
  13. Hi all Have a nice day I had changed my car from carbo to injection but the tachometer not working Could you please tell me how it works with the ecu Thanks
  14. Tomorrow will send pics for u I have avometer only
  15. Exactly But the fuel gauge is well now but RPM not So iam looking for manual
  16. Exactly But the fuel gauge is well now but RPM not So iam looking for manual
  17. Fuel gauge & RPM both of these not working
  18. 1.3 carb. 1997 GLX I don't know any info. To the other one
  19. Dear ricardom First I'm sorry if my English not good enough to you I had changed Guages MB And the RPM not work we try everything someone said that I have to change cables bin to be compatible with motherboard
  20. Dear all Have a nice day I'm looking for psb manual for Skoda Felicia 1.3 mpi 1997 Thanks for help
