Everything posted by bolix
Octavia VRS 2.0 245 Steaming Engine
I have the same model, but when i lift a bonnet, my motor is even not so warm. because the system made the job well done. There is off course price for that ... noising pump.. . After engine stopped the pump is running for additional 10 min or so. It's not ventilator. its pump. But u can put your hand on cover and feel normal temp. If i start washing car there is no steam at all ..
vRS Engine Cover Recall
Tested and working coding Octavia mk4
Cornering lights via fog lights activation . Bonnet open, ignition on, adaptation, ignition off, after all restart MIB 09 CENTRAL ELECTRIC · Leuchte 12 NL L B45: Leuchte 16 BLK SL B42_C31 Lampendefektbitposition 12: 38 38 Fehlerort mittleres Byte DTC-DFCC 12: 24 22 Lichtfunktion B 12: Abbiegelicht links....................... same Dimmwert ABC 12: 100 127 Lichtansteuerung HD ABC 12: always ........................................same Dimmwert DEF 12; GHI 12; JKL 12: 0 0 Dimming Direction DEF 12; GHI 12; JKL 12: maximize ...........................same · Leuchte 13 NL R B5 Leuchte 17 BLK_SR B4_A61 Lampendefektbitposition 13: 42 42 Fehlerort mittleres Byte DTC-DFCC 13: 25 23 Lichtfunktion B 13: Abbiegelicht rechts...................... same Dimmwert ABC 13: 100 127 Lichtansteuerung HD ABC 13: always..........................................same Dimmwert DEF 13; GHI 13; JKL 13: 0 0 Dimming Direction DEF 13; GHI 13; JKL 13: maximize..........................same · LWRKonfiguration: Static AFS light: ECE R119
Octavia RS 4 vs Superb Sportline 3
my previous car superb 2020 and new one octy rs. so i can say a lot . am i missing my super b - yes ... thats all. You cant compare this 2 vehicles. One is 2.0 tdi 150 ps other 245 ps TSI , both DSG but diferent in any ways . It's depends what u searching for . bigger space , small costs , stronger car , super b is 3rd genration , no sickness , no problems at all, smooth display activities, no problems in one word. NX RS - looking nice
Ambient light upgrade in the shop
Octavia MK3 -- ??? its not not the same model. u need to find app for mk3
- Ambient light upgrade in the shop
Connect obd 11 go to : 09 central el. , find adapatations and folllow this steps above.- Hello skoda octavi 4 Coding List and Adaption
well u could save your 50 EUR or 30 pounds to activate additional ambient light colours open the bonnet 09 central electrics - adaptations - interior light hmi config first and second value should be 7fffffff and ignition of, ignition on turn multimedia on , find ambient lights and shoul be activated additional 20 colours- Ambient light upgrade in the shop
well u could save your 50 EUR or 30 pounds or similar value . you can acivate it with obd 11 09 central electrics - adaptations - interior light hmi config first and second value should be 7fffffff and ignition of, ignition on turn multimedia on , find ambient lights and shoul be activated additional 20 colours- Hello skoda octavi 4 Coding List and Adaption
well i though the same . but aafter just 1 times all car became so dirty . try it ...u will quit. espec if u use sonax ... pure watter - no sence during this winter days- MK4 CarPlay
as i can see u haave 2 messages , 4 updates i think. do it- Hello skoda octavi 4 Coding List and Adaption
yes with obd 11. if you have it then u can do 1 click app deactivations otherways 09 central electrics - adaptations - waschen - waaschen one KL 15 - active - NOT ACTIVE - RVC waschen HMI - active - NOT ACTIVE HEADLAMP WASHER system - anzahl betaetigungen frontwaschanlage pro SRA aktivierung - mine was set to 10 th time - SRA bei waschwassermangel - active - not active- WARNING Remote locking vulnerable to attack
faraday pouch is one of the solution and i have it for long time , but thats nothing if u dont keep your keys in the boxes during the night . Its very easy to open the car .. so be smart , use faraday box for 2 keys https://www.youtube.com/watch?v=0AHSDy6AiV0 the system work identical today .- Hello skoda octavi 4 Coding List and Adaption
i just disabled mine. I don't need every 10 th wash .- Hello skoda octavi 4 Coding List and Adaption
tnx GOOOOOOOD fINNALY we can shut down sound actuator or u can set to 10-100% mine is now on 20% and its really much better to drive. module A9 Structure borne sound - adaptation- volume of structure borne noise act - choose betwen 0-255- Hello skoda octavi 4 Coding List and Adaption
maybe you didnt noticed but you can change tachometer view . Control unit 17 - Adaptations - tachometer end value - my first version ,default was 2 with end speed 260 now its version 6 , after you enter desired value press ignition off , ignition on and new version will be shown instantly- Hello skoda octavi 4 Coding List and Adaption
someone asked for video on display. NO! its not mirroring bt aplication u can use has also mirroring . its called fermata auto . u can watch you tube , tv through mirroring. but there is some steps before you can install this app on yours mobi. first of all u need to install king instaler then AAAD app, you can find it on net. after that try to find version fermata auto 1.8.7 and install with king instaler. You can easiliy find all tutorials on github.com Android auto with new version has some restrictions so only way is install with king installer and if you want control through stering wheel there is fermata control. cheers. it looks like pic down. hope admin will allow this post . free vers of aaad will allow downloading only 2 app.- Best must have accessoaries for Octavia
ohh pitty, i know the same deflector can be purchased on aliex but u must be prepared for 3 months waithing- Hello skoda octavi 4 Coding List and Adaption
Ok i found out that we need to verify 3 steps in registration which was normal, then brake must be on, hood open, ignition on... SFD unlock each module in aplication , not only 1 , u need to unlock all...after that u ll be able to do some coding. So i finally managed to turn of seatbealt warning, drl etc, ok did you you findout that u can watch even you tube videos even with handy off, without youtube premium acc or watching tv throug mirror link but mobi needs to be on. And all that while driving a car- Hello skoda octavi 4 Coding List and Adaption
i tried all of that with no successs. i receiving messages on obd like.... something went wrong... try again .- Best must have accessoaries for Octavia
wind deflector also good for rain. in the winter time or summer during the rainy day you can drive without being wet . nice design looking top on octy ...visit kopacek for manny other things- Hello skoda octavi 4 Coding List and Adaption
i have obd 11 but im not able to code anything of it. its not possible , or something went wrong. i couldn code even fan level display ...- Hello skoda octavi 4 Coding List and Adaption
so far no app can be coded. still nothing. hope will be soon.- can not log into profile
straith to the dealer for major software update . i had similar problems , but with 1803 v is now fine but few prrobl remains - Ambient light upgrade in the shop
