TadyTheFish
Everything posted by TadyTheFish
  1. Ahhh the attachement quota is full 🤦‍♂️ anyway to reset it or increase the limit?
  2. What is the difference between Cupa and Cuna? Max to min (1L i think) per 500km of highway. Btw how do I upload images? I could do it before but now the limit is only 436.71kb???
  3. So the latest info is 30Nm,70Nm and 3x 90° ? kinda big jump in tightening force don't you think?
  4. Sooo here is the thing. The balancig shafts and the crankshaft sprocket don't have any markings, the manual for the Seat (184hp engine) says that the cranckshaft should not be removed. So if you want to pull out the crank you need to mark everything down. I didn't do that. I left the oil sprays in and honed the cylinders carefully. The botom part of the engine is complete, now I'm waiting for my friend to finish the head (new seals, clean the ports an valves and check the flatness of the head) Now I need some info on the tightening of the head bolts. Haynes manual says - 30Nm - 70Nm - 90° - 90° - 90° But the Seat manual for the same engine says - 30Nm - 65Nm - 90° - 90° Any advice? I woild rather tighten per Haynes instructions but 3x 90° is kinda alot. I'm affraid I'm honna break the bolts or even pull out the threads?? Thank you
  5. Thank you. I will check the manual 👌👌😁
  6. I know about the rear swal and the sender wheel. It can be done without the tool. I'm asking about the balancing shafts. 😁
  7. Did any of you hone the cylinders? I want to hone mine since the crosshatches ar kinda blurred but I need to take out the oil sprays and to do that I need to take out the crank shaft, but the problem is that the balancing shafts don't have any markings on them. Then I got a service manual for a Seat with the 184Hp engine and it says that the crankshaft should not be removed??? How am I going to take out the sprays and change the main bearings?
  8. 🙈🙈🙈🤣🤣🤣 What was so bad about it
  9. I ordered new - Head gasket - Head bolts - Head module bolts (18pcs) - piston rings - conrod bearings + bolts - main bearings + bolts - thrust bearings - crank seals - cam seals - charge cooler gasket - exhaus gasket - oil pump belt - oil pump seals - injector seals - injector bolts - and other bits and peaces I'm not changing the main blet and punp since I changed them 8k ago (the pump was leaking) but I didn't have the money to rebuild The bores are not scratched but they need honing. The cross hatches are bearly visible. The piston skitrs are ok. They show some sign of use but nothing scary. I don't have experience with these things but I showed them to 3 mechanics that are my friends and they all say they can be reused. I need to clean them
  10. I cant upload any more photos. Anyway the pistons are good only the rings are shot to hell. Mine used up 1L per 400km of highway use. The bearings are ok but I will replace them. I'm a little torn up about replacing the main bearings. Mine has 200.000km so I'm thinking if the engine is open I should spend the extra cash and replace them also
  11. Is it possible if you remove the crankshaft? I only ask cuz my top end of the engine is without any problems.
  12. I have a bit of a stupid question. I'm not a mechanic but I was always told that the pistons can't be removed from the bottom. But today a friend of mine that is a machanic told me I can???? Wtf is it posiible on this engine?
  13. 04L107065M is in mine... What is the 001 in the end? I'm affraid to tear the engine appart to find that pistons need changing
  14. I also cannot find any pistons in stock. Why is that?
  15. Nice to hear that! Do you know the width of the original oil rings?
  16. Hahaa.. I will continue to talk to you in english since this is an english forum😁 how much for the blick/pistons and head? Are you going to do this work at Vrtač?
  17. Where are you from (since you are talking about DDV 🤣🙈) are you from Slovenia? I'm thinking about pulling mine appart. For me the biggest problem is that I will be without a car
  18. I can tell you that you will be dissapointed. Skoda has no good will I bought mine used 4 years old and I made one non authourized service (oil change) when the car was 5 years old I noticed that there was some rust areound the license plate lights.. I spok to a friend of mine that work at a authourized Skoda service and he tried to fix it under warranty. Skoda told him that the request is denied because one of the service intervals was not made at a authorized service. The chassy has nothing to do with the service intervals and still it made no difference
  19. Yes please keep us posted. If you decide for a rebuild ask for some pictures😁
  20. Hi sorry for the long delay I had been busy Here are the logs AdpLog Address 01,04L 906 021 EM,channel IDE07903-Adaptation of ash mass,adapted from,0.00 g,to,0.01 g,Tuesday,10,May,2022,21:24:47:00009 Address 01,04L 906 021 EM,channel IDE07903-Adaptation of ash mass,adapted from,0.00 g,to,0.01 g,Tuesday,10,May,2022,21:25:22:00009 Address 09,5Q0 937 086 AA,channel IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,adapted from,not active ,to,active ,Sunday,31,July,2022,15:23:18:00009 Address 09,5Q0 937 086 AA,channel IDE08542-ENG125656-Access control 2-Regenschliessen_art,adapted from,once ,to,Permanent ,Sunday,31,July,2022,15:23:50:00009 Address 09,5Q0 937 086 AA,channel IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,adapted from,not active ,to,active ,Sunday,31,July,2022,15:25:31:00009 Address 09,5Q0 937 086 AA,channel ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,adapted from,not active ,to,Blinken links Dunkelphase ,Sunday,31,July,2022,15:29:43:00009 Address 09,5Q0 937 086 AA,channel ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,adapted from,maximize ,to,minimize ,Sunday,31,July,2022,15:31:10:00009 Address 09,5Q0 937 086 AA,channel ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,adapted from,not active ,to,Blinken rechts Dunkelphase ,Sunday,31,July,2022,15:31:59:00009 Address 09,5Q0 937 086 AA,channel ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,adapted from,maximize ,to,minimize ,Sunday,31,July,2022,15:32:54:00009 Address 09,5Q0 937 086 AA,channel ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,adapted from,127 ,to,0 ,Friday,05,August,2022,16:45:09:00009 Address 09,5Q0 937 086 AA,channel ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,adapted from,127 ,to,0 ,Friday,05,August,2022,16:46:11:00009 Address 09,5Q0 937 086 AA,channel ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,adapted from,127 ,to,0 ,Friday,05,August,2022,16:46:38:00009 Address 09,5Q0 937 086 AA,channel ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6,adapted from,maximize ,to,minimize ,Friday,05,August,2022,16:47:30:00009 Address 09,5Q0 937 086 AA,channel ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7,adapted from,maximize ,to,minimize ,Friday,05,August,2022,16:48:13:00009 And Here is the CodingLog Address 08,5E0 907 044 N,recoded (Long Coding),from,02010104002100011005000100101000,to,02010104002100011005004100101000,(73430/031/00063),Sunday,31,July,2022,15:19:26:00009 Address 09-02,5Q0 955 547 ,recoded (Long Coding),from,00005D,to,06805D,(73430/790/00205),Friday,05,August,2022,16:36:50:00009 Address 09-02,5Q0 955 547 ,recoded (Long Coding),from,00005D,to,06005D,(73430/790/00205),Friday,05,August,2022,16:37:04:00009 Address 09-02,5Q0 955 547 ,recoded (Long Coding),from,06005D,to,06805D,(73430/790/00205),Friday,05,August,2022,16:41:37:00009 I also changed the function of the DRL so they blink with blinkers. That is why there are extra entries Thank you
