Everything posted by pepeEL
Do Superbs have heated seats?
I have SKoda Kodiaq 2019 and i have onlye heat seats. I have infortaiment MIB2.5 with LCD 9,2" and i dont have in menu clima this popup with heat seats ? How i can activate it and what i must change... coding adaptation....pleas help
Stereo upgrade
Yes but you use without spare tire. I want save spare tire and subwoofer. From yesterday i mount Audio System US8 Active Evo. Today probably finish. When finish i show.... How connect you subwoofer to MIB 2.5 high ? Activate output for subwoofer by mods eeprom ?
Stereo upgrade
I have Kodiaq with 7 seater and no found any subwoofer to mount it in spare tire... All is to high width and can not close seats. I compare Cervin Vega 12 VPSTX12 with Musway MW1000A. In my country available only Musway. I buy it and in my opinion it is the same subwoofer all the same as cervibn vega which @spud75 mount , only other logos. Musway is too big , but user @spud75 write that Cervin Vega. Of course in all remove lower bracket and mount rubber foot. In my opinion i am from poland and maybe probably i have other spare tire than user @spud75 . I as user about number spare tire but no respond. Talking in this topic https://www.briskoda.net/forums/topic/523126-power-cable-for-subwoofer-or-amplifier/#comment-5940130
Power cable for subwoofer or amplifier
hallo @spud75 are you there? Please help me
I test next subwoofer Audio System SW11 and also is wrong. When remove lover bracket and put it in in the spare wheel, the middle membrane rests on the rim again. Does your Cervin Vega really not touch the middle rubber membrane of the wheel rim after installation? Please, please, take the measurements I asked for, and the most important dimension, when you put something flat on the diagonal legs, is the distance to the middle membrane from this flat level? Please. And give me the exact model of this subwoofer you have and what spare wheel number VW you have(show on picture where you find number). Thanks
And please check what is VW number your rim please.
- Power cable for subwoofer or amplifier
Measure if you can please. I'm also wondering what you have in your subwoofer. If you can, measure the subwoofer by unscrewing the feet from it and placing a spirit level on two diagonal feet, for example, and the distance from the spirit level to the middle membrane, which I marked with an arrow in the photo. I want to see how deep the speaker is so that I can possibly look for similar ones. And the second measurement is by placing the spirit level diagonally on the large outer membrane and what is the distance from the spirit level to the upper part of the inner membrane. I would be very grateful for these measurements and you will help me a lot in installing a subwoofer for me :( Also measure the thickness of the casing from the top surface to the bottom of the feet (the factory ones, i.e. when you unscrew your rubber one)- Power cable for subwoofer or amplifier
But in my case, when I put the speaker in, the membrane rests on the rim surface. I tried it on without the mount that you wrote about that needs to be cut off. I felt the speaker resting on the soft membrane. Can you measure the two dimensions that I marked, then I will see if the rim is the same. Or take out the rim and find the VW numbers of the rim. But in your subwoofer, the speaker may also have a slightly different profile and have a larger cone, which is why the membrane may not be touching?- Power cable for subwoofer or amplifier
Subwoofer Musway MW1000A which i buy is wrong... i remove lower ptotective enclosure and put ad you some distance where screew from enclosure but when I put the wheel in the space and closed the seats, the inner membrane touches the surface of the wheel, the inner part which is the most recessed. Doesn't your internal speaker membrane touch the wheel rim? Also show a picture of the inside of your wheel rim without the subwoofer?- Power cable for subwoofer or amplifier
I use this editor. Sound Editor I also replace standard skoda speaker to speaker Audio System X165em evo and now i try add subwoofer. Try Audio System SW11 but it has size width 135mm, and now buy Musway MW1000A which has 120mm and when lower ptotective enclosure will be moddified it will be ok. When remove lower ptotective enclosure i can close seater and has about 10mm gaps between the subwoofer and this seat bracket. I think and try also use rubber feet in hole when screw and check it will be ok.- Power cable for subwoofer or amplifier
Very thanks for your reply. I am waiting for photo please. I buy subwoofer Active Musway MW1000A and he has the same size and construction as your. Then i modified parametrization MIB in Kodiaq to activate connections to subwoofer on plug quadlock MIB. Also activate center speaker. Now in radio i can Control knob subwoofer.- Power cable for subwoofer or amplifier
Hi @spud75 I think about mount also subwoofer in my kodiaq with also 7 seater. I know that subwoofer original Canton has 117mm. I try mount in my which has 120mm but probably has problem. I also has in my kodiaq spare tire and i want have it. Did you have any solution how modified the bottom of the sub enclosure ? Did you have any photo ? Also did you have photo how install power wire from battery to subwoofer ?- infotainment update
- Using Android Auto
Hi all. I have Kodiaq with MIB 2.5 with screen 9.2 inch and no knob and only touch button. Please tell me if anybody run Android Auto Wireless on this unit ? Is any chance ? Also if anybody has run Android Auto Wireless in kodiaq please give more info how model and numer unit has mounted? I change all adaptation which found in Internet on my unit but still only connect by USB wire What i change: Control unit: 5F Information Control Unit Adaptation Google_GAL_Wireless: On wlan_5ghz_switch: activated Apple_DIO_Wireless: On Apple_DIO: on Google_GAL: on Wifi_Client_HMI: on Mirror link: On- Virtual cockpit?
ok found in Adaptation in Instrument and name Presetation tube. Now i have Version 3 but when change on whatever version 0, 1 2 , 4 .... A,B....F i have the same presetation. onlu version 3 is other than all other version. Summary. I can only set 2 view theme.- Virtual cockpit?
But in vcds where ?- Virtual cockpit?
But how activate or disactivate ?- Virtual cockpit?
Is any chance to upload themes from virtual cocpit after facelit to before facelift ?- MIB 2.5 Codding to show climate and heat seats
Hi All I have a skoda Kodiaq 2019 with Columbus MIB 2.5 I found on FB screen that in some skoda with MIB 2.5 can codding to show menu heat seats. My no show. Only show led on button when turn on heat seat. Anybody know how codding or something else to run this on my MIB 2.5 ? Also when i change temp climate only show on screen with small number temp. Is any chance to open view climate ? I can run it only by press button MENU on climate and then show me menu view climate. Thanks.- infotainment update
