Everything posted by KinderBean
Car wakes up during the night the odd time
If you can let me know what battery monitor you use I will get one myself and I will check the same (Mk4.5 2.0 TDi [DXRB])
- Can I reset the Battery Management System (BMS) MK4.5
Car is 2.0TDi purchased new (Mk 4.5) and about 4 months old (DXRB engine) and the most basic trim level, my original query was whether I can reset the BMS (without disconnecting the battery) because by charging it incorrectly multiple times, I've stuffed it up and given it false information... --------------------------------------------------------------- 03 Brakes System description: ESC Software number: 5WA614517DQ Software version: 0331 Hardware number: 5WA******** Hardware version: H31 Serial number: 6144******* ODX name: EV_Brake1***********NECE ODX version: 006026 Long coding: 52185228A48B*************** Trouble codes: U140000 - Function restriction due to insufficient voltage Intermittent
I decided to connect my 12v charger because I recently bought OBDeleven and didn't want to run the engine for hours whilst I played wth the App.... I've now done this multiple evenings and left it charging overnight (Ctek MXS 3.8 charger) I noticed belt squeeling during every warmup since and I now think the alternator has been over loading itself I realise I should have been using the negative teminal on the bulkhead to charge. I was wondering is there a way I can now reset the BMS without taking the terminals off, it's a new car and I didn't want to cause any extra issues by disconnecting.... it was bought in August (2.0 TDI)
side sun shade for Skoda Octavia Combo (estate/sedan) facelift 2024
ideal for Car Camping in the hot weather (keeps the bugs out) 👍
here is an idea for you https://solarplexius.co.uk/uk/
- Transmission Oil Specs and amount
- [HELP] Octavia Mk4 (2024) – SkodaID login & S-PIN not working anymore + can't reset infotainment
- Skoda owners I need some guidance!
Buying first VRS help
interesting, I have a brand new 2.0 TDI DSG arriving in 6 weeks (I assume with the DQ381) do you know if these boxes still have the same flaws or have they had a big update?
