enoktakenokta
Everything posted by enoktakenokta
  1. By the way how can i learn whether my camera appropriate or not?
  2. Thank you for guidance. As i see it needs knowladge and experience. Because i have not these 2 qualification i should find a specialist.
  3. Sometimes value on the navigation screen do not change for a while, so sometimes it does not work well. But, value on the trip computer is more dynamic, so nearly all the time it shows true value. Both the map and software are up to date. Is this normal the different speed values for trip computer and columbus navigation screen?
  4. Hi. As you know if lane assist turned on system requests intervention from user every 10 seconds. Is there any way to increase intervention time maybe for every 1 minutes or totally cancel it? Thank you.
  5. Hi. I have a problem with TSRS. The speed value on trip computer and on the columbus screen are different. That is to say, when the value on the trip computer can be “120” but on the columbus navigation screen can be “140” or “120” or “110”. The values are sometimes the identical. I am using latest map and software. What can be the problem and how can i solve the issue?
  6. @Tell As you advised, i downloaded 25.23 mib 3 map which is vw release and from MartiniB' post. But, because the weather conditions are very harsh here,i will load the map when the temperature becomes reasonable,
  7. @Tell Thank you for your reply. I am doing it offline as you said. As far as i understand, there is no mib 3 map belongs to November 2023 and i should wait for new map for mib 3. It seems that 25.23 version is the latest map which is usable for me. So, i will try @MartiniB map and load as soon as possible.
  8. By the way, i loaded 25.2023 map several weeks earlier, which one i downloaded from offcial site and the map's data is 12.22 . Because of this, i need last map for mib 3 columbus.
  9. Hi, i have a question about maps. My columbus is mib3 and firmware is 0270. Because new map data is available, i want to load it. As far as i know my columbus is mib 3 and i can only use mib 3 maps. But, for the last map data(November) i could not find a data including mib 3 data, but for example May 2023 map datas were also in mib 3 like mib 1 mib 2 and maps. If there is a member knowing these issues please help me and so make use latest map. Thank you.
  10. 1-2 weeks ago i noticed that there are some kind of spots on the car, white colored. First, i tried turtle wax tar remover, although i know that it’s actually purpose is not that and producut’s actual usage is different. It helps to solution but there needed force and time; one by one is diffifucult and hard. Yesterday i bouht a solution which is used to remove cement. I applied to small area, there was no damage, but as turtle wax it did not help. I will try to send a video, i hope that it clarifies the problem.(i started topic here, if it is wrong i change) IMG_0337.MOV
  11. Actually in my country we do not have maps in columbus, that is to say the map does not come with car pre-loaded in factory. So i have a columbus without map. As far as i understood you actual problem is i dont have map.
  12. Hi people. I have a problem with the system, that is to say all speed values are wrong. For excample in my country highways’ speed limits are variable but minimum 120 km/hours. But, my car read 30, 50, 70 etc. So everyting is wrong. My car is not a car which has this system added st production; it is added via a programme. Is there anyone has a experience and information. Also, the person who made programming said that if TRS is working other 2 function works without any setting. But i can not check wheter pedestrain recognition system and bicyle recognition system. I cannot find menu or setting on the columbus. That is to say, i cannot be sure whether systems work or not. How to check all these systems.
