Everything posted by Othen
All Weather tyres and Summer tyres
Thank you for that, would I be right in thinking the MO marking is of no significance whatsoever on this 7 year old, 70,000 mile car? Alan
Thank you for clarifying that, I’m relieved to know my car has the correct tyres. I’m slightly confused as to why the MO marking was in any way significant, this is a 7 year old, 70,000 mile car, so the original Continental 225/40R18 tyre probably didn’t have a MO marking (but that was probably 2 tyres ago). Whenever it was changed I’d have just told the garage to fit the same tyre, I have no idea why it would have supplied one marked MO, but if it doesn’t make any difference then why should I be in any way concerned? I’ll check the other 3 tyres tomorrow to see if they are also marked MO (I suspect there will be at least one more as I normally buy them in pairs, unless it has been to fix a puncture). Alan
Ah, that was just my fat fingers typing on an iPad, it should say 225/40R18. Do we agree that is the right size for the car? I’m not sure I understand the ‘MO’ issue, are you saying my motor car could not have come with Continental tyres (in that case you would be mistaken - I am the only owner)? What is the significance of the ‘MO’ marking (apart from being approved by MB), are you saying they are unsuitable for my motor car? I’m a bit confused. alan
Hi, Thank you for that, but it seems (to me) unlikely that the car should have come with 225/45R18 tyres when the sticker inside the fuel flap lists 225/40R18 (see the photo below). I’ve owned the car from new, it has had a few new tyres over the past 7 years, but I have always had them replaced with the original size. I think you must be mistaken about the 225/45R18 tyres - I have no idea about the MO bit, the tyres would have been supplied by a reputable garage either to replace a worn out one or a puncture. Does it make any difference? Alan
... are we saying that Skoda do not fit Continental 225/49R18 as OE? See above, I bought the car new from a Skoda dealer so I’m the first owner, that is what it came with. Alan
I bought the car new, it came with the same Continental tyres as I have now (I suppose about 8 tyres have been changed over the past 7 years and nearly 70,000 miles through punctures and wear).
Many thanks. You have already exceeded my knowledge of car tyres (I'm better at motorbike tyres, they are a bit more critical). Whenever I need to replace 18" tyres I always just ask for an exact match (I think it is best to keep with the OE, manufacturers don't often get it wrong).
Okay, here are some photos of both tyres, the Continental (18”, on an alloy rim) and the Yokohama winter (on a 16” steel rim). I measured the consumption using the onboard computer. It was on a route I do quite often from Corby to Pentney (near King’s Lynn) - about a 140 mile trip, probably half dual carriageway and half good A roads. I normally get just about 50 MPG (maybe a tiny bit more) with the summer tyres, driving exactly the same way (60-70 MPH, just me and the dog in the car, full tank of fuel, no stops) gave 58 MPG on the winter tyres. Akan
Okay. I'll photograph both tyres when I get back. The 18" wheels are alloy, the 16" are steel. Alan
... I'll have a look after I've taken my son to school - does it make that much difference? Alan
Many thanks, the calculator is really useful. I’ve just put in 225/40R18 and 205/55R16 and get rolling circumferences of 2001 and 1985mm respectively, 6mm difference is 0.3%, and the 16” wheel has the slightly smaller dimension.
Agreed, I don’t think this is anything to do with summer and winter rubber, just the narrower and higher profile tyres.
See above. I have checked, and the width is indeed reduced from 225 to 205, so about a 10% reduction. The running pressure for the 16” tyre is also higher at 2.4 bar (as opposed to 2.2 bar for the 18”). The car runs well on the winter tyres, they are certainly quieter (due to the higher aspect ratio I think). It is easier to spin the front wheels with them, particularly in the wet, which is unsurprising.
See above for the details. The sizes are both standard for the car (225/40R18 and 205/55R16 - which is the same as my full size spare), so I’m pretty sure the rolling circumstances will be the same (although I have not checked). I can only put it down to a 10% narrower tyre and slightly higher standard inflation pressure. Alan
Yes, of course: the summer tyres were Continental 225/40R18 (OE fitment ) running ar 2.2 bar, the winter tyres are Yokohama 205/55R16 at 2.4 bar. I checked the pressures were exactly as per the recommendations myself. I was pleasantly surprised at such a big improvement. Alan
One unintended but most welcome consequence of changing to my winter wheels and tyres has been much improved fuel consumption. On the 18" alloy wheels (225 width I think) my Superb diesel would return just about 50 MPG, I took the car to Norfolk last week (130 mile round trip) and it did 58 MPG (on 16" wheels, 205 width I think). That was a nice surprise. Alan
Superb II Rear Shock Removal
The right side rear shock on my 2013 Superb diesel estate has a slight weep, I've bought a pair of replacements and had a look at changing them today. It all looks straightforward, apart from the 21mm bolt that secures the bottom and faces straight inwards to the coil spring. There doesn't seem to be a way of attaching a socket spanner (which I would prefer) apart from removing the coil spring (which I could do, but would prefer to avoid if I can). Would it be possible (and safe) to use a 21mm ring (combination) spanner, which might just have enough clearance? If so, how could the nut be torqued up on reassembly? I'm hoping someone has done this and come up with a simple solution for what looks like an otherwise simple job. I've attached a photo which explains the problem.
