Derv doctor stage 3 turbo upgrade
once again lol i begin
anyone got any experience or opinions on the derv doctor stage 3 kit?
the derv doctor
Phase 3
Phase 3 has the addition of a Forge front mounted intercooler and an ATP exhaust manifold.
The ATP replacement manifold is also built to flow much much better than the stock unit. Overall flow has been improved more than 50% and virtually ALL of the restrictions built into the stock unit has been removed in this replacement design, resulting in more HP and torque. The additional benefit of using this high flow, thicker wall, cast unit over the stock unit is the ability to improve breathing at the exhaust ports as well as providing the necessary exhaust volume to maintain high boost/high RPM operation. The free flowing design also helps keep the EGT (Exhaust Gas Temperature) and subsequently engine temps down to allow more timing and less detonation.
Phase 3 is the maximum that can be obtained on the standard K03s turbocharger, around 250 bhp is seen from the conversion
