Urgent help needed
my dipped headlights , indicators and windscreen wipers have suddenly stopped working on my 03 superb 19tdi , any ideas chaps :mad:
Fuses?
Maybe an x relief issue, has the heated rear window also packed up?
yes heated window and fog lights are off too
Check if the footwells are wet, and let us know.
footwells have been wet in the past drain holes been cleared out ect been dry now for months, going on holiday tonight just aswell i dont need the car , will get back on here next week so if you have any thoughts guys please leave them here :thumbup:
Sounds like rusted contacts if you've had the wets before.
car has been fixed at main stealers, turned out to be the ignition switch and a relay, cost me £290 the robbing ******** :mad:
Lummox was right then, as usual. "X" is the contact on the ignition switch which becomes live at the first key position. Price up the same bits at GSF.
rotodiesel.
I wouldn't if you've already paid the dealer... :eek::eek::eek:
Btw Roto - I've only ever ordered Superb specific parts from the dealers, like trim panels and so on. With the exception of (my current) cambelt & tensioners everything else I've changed is aftermarket.
rotodiesel.
Hi Rotodiesel,
Could you tell me here please, what is GSF? It is interesting subject here, but the dealer was so expensive.
Thank you
Soviet:thumbup::)
GSF = German Swedish French
