Leaking coolant - Superb 2.0 Tsi 4x4 2019
Coolant level has been falling since the summer. It seems to be mainly happening after drives, although it did also drop a little when it wasn't driven for five weeks. Ive been topping up with G13 coolant as needed, but it's just putting off the inevitable imvestigation. No obvious leaks in the hoses. Really hoping it's not the water pump. Before i take it to the garage, what could i check myself?
TIA
Most obvious is to check for signs of coolant on the block or general area below the vehicle when parked.
Most likely failure is unfortunately the water pump already mentioned.
Expansion caps have been known to fail and leak as well.
Thanks. If it's the pump, would coolant still leak when the car is not being driven.
Yes. Good look around for damp or signs of coolant should give away the general location and point towards a failure area.
Speculating only puts the price up in your head before the faults even found.
Recently Browsing 1
