help
can anyone tell me how to bleed fuel system on a 02 1.9tdi fabia thanks a lot
Best job is to fill the filter up manually and go from there. It should be self bleeding but if you get enough air in the system (Like when you change the filter and don't fil it up) then it can take a while and run your battery flat.
