charge for getting a wing sprayed
depends very much on where you go to get it done, where I work (manufacturer approved) we would paint the panel and blend out into the door and bonnet so, although I am not sure how much, it would not be cheap!!
A lot of smaller body shops would do it a lot cheaper though
:iagree:
there's no real answer to this question really...
one thing i will say is that it is far easier to spray a wind with it already fitted onto the car, but then you end up missing out on the hidden bits being sprayed, you could however do the 'hidden' bits with a spray can then fit the wing on then get it sprayed properly... it is almost impossible to fit a sprayed wing on without scratching it or damaging it
around the £100 mark?
Probably. I was quoted £190 for a small dent repair and repainting a wing, but that was at an expensive, franchised bodyshop.
I had my bonnet resprayed on my corsa for £160 and it was a top notch job
