Where is the coolant temp sensor on ATD engine please?
Ummm, I don't really need to say any more do I? Where the hell is it - already had a scan around the rad and pipes coming out. I suspect it is well hidden! :rolleyes:
the same place it is on the ASZ or BLT ?
back of the housing on the R/H of the head below the fuel pump ?
I didn't know where it is on my own engine. :o Thanks for the pointer - It was a little dark back there so will check there in daylight. :thumbup:
I knew! I chickened out though. :rolleyes:
TBH if the engine is cold and you can bung the hole whilst faffing about, it's an easy job.
J.
