What speakers?
I think this is the right place for this question
Ive got Kenwod KDC-W5541U headunit (which is really annoying at night with the extremely bright blue light, however i digress) in my octy 1 estate
Im after some speakers for around £30-40 to improve the sound in my car as its currently sh**e, ive diconnected the rear tweeters but its still not very good.
so whats good and whats not? also any idea on what size i need?
cheers
Nick
any luck? i want to know the same. but no one seems to have the awnsers.
Isn't it adjustable or is there a setting for the dimmer activated by your lights?
For that sort of money, you'll not really improve the sound I'm sorry to say.
If you pop off the front grill cover you will see the size. You will also need a harness if you wish to keep the original connectors.
yes there is a dimmer, however all it dims is the led display not the stupidly bright blue lights around the usb socket and volume switch.Im sure i could supply the lighting for a concert with it!
Ive found the infinity 6522si for about 45 quid which i can stretch to. the only problem with my speakers is there is no bass at all whatsoever, its terrible, my M reg 306 with the OEM HU had a better sound than my octy
ive got a 2x75w amp to fit somewhere behind the dash, surely a couple of good compontents rigged up to this will improve sound? my alternative is to put it in the boot, and bridge it to one channel for use with a sub? any ideas?
sorry to thread hijack, but my question is so similar!
