Wheel Bearing
Hi Everyone,
I've noticed that when I drive my Fabia recently, the car is generally a bit louder. It doesn't sound like it's the engine, but more like a loud humming/whooshing, like I'm inside a plane - sorry for my very technical explanation :rolleyes:.
Occasionally - especially when on the motorway at speed, there seems to be an intermittent squeal, coming from the rear of the car I think.
Does this sound like a wheel bearing that's on it's way out?
Thanks,
McMobile x
Either that or could be a tyre getting noisy.
Thanks Lummox - what do I have to do if a tyre is getting noisy?
I have just replaced the tyres on my Fab VRS and the very slight humming noise has gone.
It sounded just like a wheel bearing.
hmmm sounds like the same problems as I've got. Humming noise coming from the rear. Think its a calliper sticking. Going to try it on new pads as the one on it now are quite low. Hopefully wont be too expensive.
I was told to crank the car up at the back, (make sure you put a brick infront of the front two wheels) let the handbrake off, and spin the wheels. If you can hear a grinding, then it might be a calliper sticking. Worth a try. Thats how a found out where it was coming from.
Mine goes in tomorrow. :( Will let you know anyhow.
