How do you remove the front bumper?
Hi everyone, how do you remove the front bumper on a fabia vrs?
Inside each wheel arch is 3 torx screws holding the arch liner to the bumper. There's also one, maybe two, underneath where the arch liner punches front toward the foglight. Then at the front underside, there are 3 clips holding the undertray to the bumper. You kind of pull and unclip them. Finally there are 2 bolts in deep by the radiator area when you open the bonnet - think they are 10mm or possibly 13mm. Then, once all is undone, gently prise it out by each wing and it will pull forward. Don't be too hasty as the foglights will still be plugged in so you need to reach in and undo those when the bumper is off (before you try to set it aside)
Cheers mate! :thumbup:
