Mail merging a tick box
I don't know if anyone can solve my problem: I am trying to set up a mail merge that originates from a tick box field in a database. This is exported to Excel, where it's converted to a 1 or a 0. I'm trying to convert it 'back' to a tick box or at least substitute 1 and 0 for 'Yes' and 'No'. The best I've been able to come up with off the internetz is the following field code:
{ IF "Bool2" = 1 Yes No }
...but this comes back with 'No' regardless of the contents of the field in the source spreadsheet. I did wonder if I needed to go with:
{ IF MERGEFIELD "Bool2" = 1 Yes No }
...but that just gave me 'Bool2' all the time???
Where am I going wrong? It's Orifice XP if that makes any difference???
Is it being imported as text rather than a number and then not working in the boolean?
If you change the = to > 1 Yes No does it make everything Yes?
As it happens, yes! And likewise if I try > 0 Yes No??? :confused:
If you set the formatting to one of those cells specifically to number what happens then?
No difference, I'm afraid... :thumbdwn:
=(if(a2 >= 1,"yes", "no"))
I've just done that and put the value in A2 and that work correctly.
If 0 you get a No if 1 or more you get a yes displayed.
I assume you're using bool2 to refer to a cell within the column?
Sorry, didn't make it clear: the coding I'm trying to get to work is in a Word mailmerge field rather than in the spreadsheet itself, and I don't want to have to do anything to the spreadsheet - the mailmerge field just doesn't seen to be able to resolve the logic??? :confused:
Bestthing to do in this case I guess would be to get the database to substitute the output of a certain field when doing the SQL to change the bool to a text yes/no
Thanks, Mark - will see how I get on attacking the problem from the other end!!!
Let me know how you get on as it's going to bug me now :thumbup:
Well, I tried everything I could think of at both the export and the import end without success, and have resorted to implementing a work-around. The reason I tried mail-merge in the first place was because blank fields cocked-up reports when they were generated direct from the database. I had hope m-m into a table of fixed structure would get round this (which it did), but it obviously introduced new problems! :doh:
So instead, I have set the database up to show 'Pending' as default text in fields, which looks a bit naff but at least allows reports to be generated how I want them... :thumbup:
Mark,
I had to revert to 'Plan A' after all, but just in case you're interested (or anyone else has a similar problem) I found the solution here:
WD2000: How to Show Access Check Boxes During a Mail Merge
Not sure why it:
a. Didn't come up when I searched originally, and;
b. Won't work when the field codes are edited manually;
...but I can do what I need to do now, so smiles all round! :)
Mark,
Not sure why it:
That's cheating, using wingdings characters :D, but hey it works so all good and handy to know that's the official way of doing it should i need that in future.
