Cornering noise
Hi everybody. I have a strange low-tone, grinding noise during hard cornering (wheel locked - maximum angle) to the right. If I press the clutch, the noise disappears. I can only hear the noise during maximum cornering. Otherwise the car rides smoothly and without a problem. The car has 45 000 km, 2.0 TDI.
Any good idea?
Thank you.
How loud is the noise ? There are a lot of things that could cause noise. Releasing the clutch will necessarily cause the car to slow down and the forces on the suspension change so the noise will change.
D
The noise is like a long "hmmmmmm" that occurs all the time as long as the steering wheel is locked to the right and the clutch is NOT depressed. As soon as I depress the clutch, the noise instantly disappears.
