Any info on seat belts
We need to change the drivers seat belt superb 130 tdi as it wont retract by its self, but have been warned that there is a safety device that could explode, if not done properly
Any advice please, and would a belt from any Skoda VW do in its place
I seem to remember a thread about this that suggested cleaning the belt when fully extended might do the trick. Can't remember what was suggested to clean it though :o
Probably WD40 or something :D
have you had the water problem? My one retracts slowly too. So i pulled it to the max a few times, gave it a good clean and it improved to bearable levels
The explosive device is usually in the base of the seat, not the seatbelt :/
I've currently got this problem, I'm pretty sure cleaning the belt/receiver will help!
I have given the belt a good clean and the receiver and its starting to retract, while doing it I found that if you put the height adjuster to the top and press the button it goes in as normal,
I will somehow have to strip the height adjuster down and give it a good clean, and also try to fix the ratchet to stop it sliding down on its own when the belt is pulled out
