Upgrading OEM bulbs
I have seen many sellers offering kits to change from standard bulbs to hids, by connecting a small box into the bulb wiring then the new bulbs
has anyone fitted these kits and how do they perform and do the bulbs last longer than the OME ones
I have aftermarket xenons fitted, they are 4300K (same as OEM) there is no comparison between them and std or even uprated bulbs.
Passed the last 2 MOT's with them fitted with no issues as the Superb has projectors headlights as std so there is no beam scatter at all (never been 'flashed' either)
HTH
HTH
I very much doubt the light goes where it is supposed to go.................:thumbdwn:
You are probably right - as it goes exactly where the halogen light went :rolleyes:
Which it would, as the HID bulbs are the same length as the halogens they replaced which is why the beam pattern did not change one bit.
