Carbonio CAI
Does a carbonio CAI off a golf mkiv fit a Octavia VRS?
Are there any fitting instructions online/pdfs?
Just be aware that the Octy vRS does need the little filter to go with it too ;)
Sarah
do you sell the little filter because i do need a new one.
Hi
yes we sell them seperate
Have 2 in stock too £17.85 + VAT
I must admit we had a guy in with an issue with his , and he had an alternate little filter on and that was wrong one , was not the Carbonio one and that caused an issue with the car
So you have to fit the correct one
Hope that helps?
Sarah
Sarah
i have always wondered what do those little air filter do .. where do you install them/
mind you , i do not own a vrs ..
Pimp My Skoda!
The link that Rob put up will help with that ;)
Sarah
Pimp My Skoda!
Sarah
is this filter then only needed with a CAI set up ?
cheers, might have a go in a bit seeing as ive had a half day at work, ive got not breather filter but a mate has one, ive had this cai on a prev skoda but i paid someone to install it for me.
Yes , have a go yourself....
Just dont tighten the carbon fibre up too much , as I have known one person to over tighten and then it cracks the carbon.....just be a tad careful there
Sarah
Have got the little breather filter but cannot for the life of me install it, its soo tight, any ideas
Have you taken off the 90' plastic bend that fits in the standard airbox. You should be left with just the straight pipe. Then this should slide inside the filter to allow you to tighten it up.
All sorted now, i had taken the elbow off but was trying to isert the corrugated tube all the way over the filter which wont happen but got it part way and tightly secured with the jubilee
