Columbus and firmware 2664 issue (dos'nt remember there last position)
Hello @all,
I have a problem with the Columbus on my Skoda Octavia 1Z (pre FL):
With firmware V1024 the navi rembers there last position.
For example: I park my car in an underground parking area, after 30 minutes I start the car again and the navi shows me the correct last position (the car does'nt see any GPS-Sat).
With firmware V2664 the navi dos'nt rembers there last position.
The same example as with V1024. But the navi shows me in the map as current position Wetzlar (a Siemens-VDO location in germany). On other cars the navi shows a position in Regensburg.
We can provoke the issue with GPS-Sat connection:
* make a reset of the navi ()
* after the startup screen (welcome to Skoda) and after the radio comes up immediately press the map button
* You'll see a screen "Navigation is starting" or something like that
* If the map comes up, most peoples see a wrong position (remember: with V1024 the navi shows the right location)
* after a while (1...5 minutes) the correct position is shown on the navi
We also make a comparison of working an non working navis:
* CAN-Gateway: not a reason --> same gateways are screwed
* Navi version: not a reason --> A, B and C versions are affected
* car fabricator: not a reason --> Skoda and VW are affected
* coding: not a reason --> same coding on navi and the CAN-Gateway (the adaptation channels are also the same)
* burn settings to burn the firmware CD: ot a reason --> we are using the same CD on an working and non working model
I disconnet the battery for 3 hours from the car. After that and one reset (after the navi founds there right position with 3D-Fix), the same problem occours....
Have any one any idea to fix that problem?
Thanks in advance.
Ciao
Edited by rj.2001
