gauges
Hi there,
I'm just considering to have some analog gauges monitoring oil (temp, pressure) and, if possible EGT.
Can you recommend any particular model. What would be the correct ranges for oil temp, pressure and EGT on a PD170?
TIA
Should anybody else be interested, I found that 19.2 climatronic setting does show engine oil temp and that's quite informative of engine real warm up process.
Only, the low display is not so comfortable. Meanwhile I've got some VDO instruments and will check how to get it installed.
On the other way the speed info is poor on highway as it shows only 2 figures.
Edited by Genoa1893
