Rather rich smelling interior
Any ideas what may cause this? At times there is a strong rich smell inside the car, noticed more last night as it made me feel quite ill.Have tried a brief search but not found much.
Edit: car is the mrs car which is an 02 VRS
Air con bacteria.
Maybe .....
You can get those cans that deodorise the air con.
Worth a punt
Carrying large quantities of used fivers in the boot! ;)
Seriously, try the aircon deodouriser, and change the pollen filter when you're at it.
Not sure what you mean by rich. Rich as in chicken sh*te or rich as in fuel fixture?!
If it's a stong oily smell, then it'll be the top Y-shaped breather hose off the rocker cover.
If it smells like a frenchman, change the pollen filter. Or remove said frenchman from the boot.
...and bury said Frenchman.
Screenwash?Leaky heater matrix?Aircon fault?
Some good ideas there...
Sadly I haven't got a boot full of cash, and certainly haven't had any dealings with frenchman!
It is more an oily, fuel type richness smell, I will be trying the aircon deodouriser, the car has recently has the y-shaped breather changed as it had split.
Thanks for the help folks.
Is it like a sickly sweet oily sort of smell? Gearbox oil stinks!
Phil
Resist................
