vrs sub&amp wiring to battery help !
maby wrong forum but am after help/pictures of where to get the cable from the amp through from the inside of the car through to the engine bay to connect to the battery on the mk1 octavia vrs ? .
Edited by N7EJA
Hello there
I have not got any pics but have just spent the last couple of days installing new amps and speakers / subs in my vrs estate. If you remove the plastic cowling underneath the windscreen wiper on the same side of the car as the battery, this reveals a filter. Just to the left of the mounting for that filter is a gromit which is easily removed to reveal a hole which is perfect for live feed to the battery. I used an 8 guage live wire and found it much easier to thread the cable through from the engine bay rather than from inside the car as it comes out up behind the golve box (very limited on hand space and have the cuts and scratches to prove it lol!).
I hope this helps
Paul
Edited by TazD
thanks guys, will try it the morn after work
if u look under the dash drivers side there a power suply under there i used that as was told on here, works well no need to go through bulkhead then :thumbup: just undo nut at fit :smirk:
Cheers guys everything is hooked up and wires all hidden. Works perfect :)
Edited by N7EJA
