Lots of error codes dont know what to do with all this lot...
I cant get over how many error codes i have on my octy, it all started this morning when the car was idling rough and yet again thick white smoke from the exhaust...These are what has been found...
00532 Transmission modual relay supply voltage B+ Malfunction
16514 02 Sensor circuit malfunction bank 1 sensor 1
16500 Engine coolant temp circuit range/performance problem
16522 02 sensor circuit high voltage bank 1 sensor 2
16688 Cylinder 4 missfire detected
16556 Fuel trim system rich bank 1
The other codes are 17549 and an airbag fault giving the code 17526
I am really really getting fed up with this car now its becoming a joke and i am stuck what to do nexy in other words is all this indicating a serious issue or is something fixable.
Thanks everyone...I am at the time of need/help :(
Forgot to say, The codes were cleared but the engine ones came back, only the airbag one stayed off
mate until you fix the headgasket you will keep getting codes up simple....
or do you just like posting :giggle:
But the car is not losing water now or oil, f-ing thing is doing me in.
refer back to your old posts and you say its drinking oil and using water :dull:
I know it was this is what is doing my nut in, I am going to get it pressure testing at the end of the week to see if/or where the weaknesses are. Just never had so many codes before.
ok 1) is it an automatic?
2) to have a sudden fault with both lambda sensors is very strange. maybe check the earths by the battery for a start
the temp range one is because it has not got as warm as it expected to/thermostat or sensor (you may even have an electric stat on yours depending how unlucky you are lol)
try all the fuses first as thats the easy bit. also will chuck out lots of white smoke/steam if its running really rich (maybe due to the lambda or temp sensor faults)
in the vagcom measuring blocks does the engine temp look about right or too cold. (tomorrow morn compare against the air temp on dash and or the inlet air temp before starting
should be similar readings
Its a manual with an attitude lol :dull:
lol ok it shouldn't have this fault then 00532 Transmission modual relay supply voltage B+ Malfunction
check the engine coding is correct
It was definatley a manual, I wonder if someone has fitted an ecu at somepoint from an automatic car, but from the same spec of car. Now im confused lol
Coilpack in cylinder 4 gone? Swap it with another cylinder and see if the fault moves to that cylinder?
Edit: Just realised it is a 1.6, so not sure the same applies
