superb interior lights
hi all new kid on the block. i run a Superb 05 reg as a taxi. Interior lights, boot interior light & door lights have failed. Checked fuses nd had com diagnosis done but nothing showed. any help or suggestions would be appreciated rgds Smet.
Do a search for 'water ingress' this is a common Superb fault and been covered many times before.
Thanks for the advice should i be looking in any particular place. Did you enjoy your diving week end?
Yes search for water ingress in the Superb I forum (link to the relevant search).
Yes the diving was amazing if a little cold at times!!
i live in Co.Durham so you were just up the road from me beautiful part of the world.
Yes it is very beautiful up there :thumbup:
The 'weird little biscuit' link is not working any more, but after a search on google this came up (different car - this is the VW 'Toerag' :giggle:, but it uses the same type of rubber bung in the plenum chamber) LOOK HOW MUCH WATER COMES OUT!!!
I have found the broken link that has been saved in a pdf :thumbup:
Fixing Passat Leak
(The Passat is the same as the Superb)
Fixing Passat Leak
Cheer's Gizmo have saved me alot of time. owe you one ta.
welcome to briskoda
the vw toerag should be named das boot.........a submarine is more water tight than that :giggle:
