Lumpy vRS
Evening,
My Octy has thrown a hissy fit tonight. It is idling lumpy and when trying to drive normally if you hit 2k revs it stutters. Am I looking at possible coil pack death here?
Evening,
It could be, or the MAF. Try unplugging it to see :)
didn't think of the maf doh!!! Frantically installing xp in a virtual enviroment to use vag com.
Unplugged MAF and same thing I also get a nice eggy smell from the exhaust
I've just been reading about this because the car's been playing up a bit and all the symptoms you describe point to coli pack failure.
I think my problem is MAF though :(
Well unplugged each coil pack in turn No1 I get pop pop noise, No 2 Nowt, No3 Nowt, No4 pop pop noise I guess I need 2 new coil packs then!!
Strange that 2 have gone at the same time?
You got through to Vag-Com yet? If it's coil related you should have some errors, and it will point you to which cylinder(s).
Steve
VAG COM 16684 RANDOM MULTIPLE CYLINDER MISFIRE DETECTED P0300 - 35-00 Thats what I got.
Edited by monkeychild
lumpy idle is more likely a vac leak, check the breather pipe on the right hand side of the engine first. After that there are lots of posts about vac/boost leak fault finding HTH :D
It lives again!!!! Swapped the coil packs checked all the spark plugs where ok and in correctly. Huzzah :D
