Rear Demister
Hello, my rear windscreen demister does not work at all, nor does the bulb for it. When you push it in the button dont light up and the misting does not work, i got someone to check the fuses with a machine they said they were ok.
What else could it be?
Also my rear passenger door (lhs) does not open from the inside or outside. How can i fix this?
Sounds like the feed wire has come off the back of the HRW switch. If you don't have heated seats, you might get in through the blank between the ASR and the filler release.
The door lock sounds like a wiring loom problem in the door, which means getting the door card off; good luck! Does the electric window on that door work? If not, that just confirms the problem.
Edited by KenONeill
