Octavia 1.8T 4x4
hi there i am new to here and was hopeing for some help with a problem on my 1.8t 4x4 octavia ,haveing owned the car for 2 months i have a problem with the oil light comeing on when driven at 3,500 rpm it bleeps then flashes then goes out oil is on the level with no knocks or bangs thankfully does any one have any idears would be most greatfull :)
welcome to briskoda
welcome to briskoda
cheers nice to see a lot of proud owners here
Welcome from a fellow 4X4 owner. emoticon-0100-smile.gif I have moved your query to the Octavia I forum where you are more likely to get the advice you seek.
Do you have an Owner's Manual for your car? If not, you can download an official one from Skoda via the link below:
http://ws.skoda-auto...wnersManual.pdf
See pages 31 and 32 for information on the engine oil warning light.
I'd get it checked by a garage ASAP.
There have been a few posts on here recently about blocked oil pickups on the 1.8T engine, the oil level may look fine but the oil is not getting pumped to the top of the engine. If I were you I wouldn't drive the car with the light on (or flashing) as running it with no oil going to the top end will screw your engine.
The garage will drain the oil out, remove the sump and check the oil pickup and pump for any blockages.
Edit: this is a recent thread...
http://briskoda.net/forums/topic/154915-vrsnew-oil-pump-and-still-no-oil-to-top-end/page__view__findpost__p__1919461
Edited by chicken_eyebrow
cheers many thanks will keep u posted
