MAF broken, Fault codes also show "Air Flow Flap" - what's this?
Hi Folks
Yesterday my Octavia TDi 110 started being hesitant under boost and has been all over the place. Instantly I thought the MAF must have packed in, so I got VAG COM on and got the result below. If the "Flap" mentioned also part of the MAF? Will thsi code clear when I change the MAF? Also, anyone have any suggestion of th ebest place to buy? I've looked at GSF and they have an "Air Mass Meter" (can anyone confirm if this is the same thing) listed at £82... Good price?
Cheers in advance for the help - will be nice to get the boost back. :D
VAG-COM Version: Release 311.2-N
Chassis Type: 1U - Skoda Octavia
Scan: 01,02,03,08,15,17,19,35,46,56
Address 01 -------------------------------------------------------
Controller: 038 906 018 GN
Component: 1,9l R4 EDC G000SG 2163
Coding: 00002
Shop #: WSC 31480
1 Fault Found:
16485 - Mass Air Flow Sensor (G70): Implausible Signal
P0101 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1J0 907 379 Q
Component: ABS/EDS 20 IE CAN 0001
Coding: 13304
Shop #: WSC 31480
No fault code found.
Address 08 -------------------------------------------------------
Controller: 1U1 907 044 A
Component: CLIMATRONIC C 0.7.0
Coding: 01000
Shop #: WSC 31480
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
37-00 - Faulty
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1U2 919 034 G
Component: A4-KOMBIINSTR. VDO V22
Coding: 00442
Shop #: WSC 00957
IMMO-IDENTNR: SKZ7Z0Y0475402
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 AH
Component: 5H Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 31480
End -------------------------------------------------------
The flap is for your air con
A pain in the tits too fit and around 70 quid too buy
You can try a reset of it with VCDS
Flap Motor Reset
08 Heater/A.C
04 Basic settings
Channel 000 (30 Secs)
001 (30 Secs)
002 (30 Secs)
You need start agin each time keying the channel numbers
HTH
