EGR
Anyone knows of any handy guide here in this forum on how to clean the EGR valve on a 1.9 PD engine ?.Want to do mine but want to know what I'm doing and don't want to damage anything.Thanks.
it's all straight forward except don't pull the pipe off the ASV diaphram it will most likely snap off-- better to cut the rubber 2-3" long and then reconnect after-- if you remove the daiphram /plastic con rod from the ASV arm/crank warm it up first with (hairdryier?)
