Indicators have failed
hi guys,
got a small issue. my indicators have stopped working, sometimes they flash a couple of times and then stop. hazards are doing the same. all other electrical items seem to be working fine.
hoping someone can help.
scottie :doh:
You need to replace the hazard switch in the dash as this controls indicators and hazard lights.
seriously? it's that simple?
Well you will have to pay around £25 for the switch then be careful getting the old switch out,but it is that simple!
easy job, just make sure you dont mark the dashboard lifting the switch out.
I find it easier to remove the centre air vents, releasing the clips at each corner with a screw driver, as the soft dash in that area is more forgiving and less likely to show any signs of damage.
cheers for the info guys. got the new part coming tomorrow.
